el. podizac stakala
crow
Poruka: 103
Član foruma od: sreda, 9. jun 2010. u 13:42h
el. podizac stakala
Poruka od crow » sreda, 31. avg. 2011. u 10:41h
Valjda je pravi podforum.
Elem, skidane mi kleme i pored blokiranog CD plejera (kod nemam naravno), pobrljavilo mi el. podizac stakala, Mondeo mk3 u pitanju. Problem je u drugom zubu na ciji pritisak se prozori zatvaraju do kraja. Sada reaguje isto na oba zuba, tj mora da se drzi da bi se podigao do kraja. Kod spustanja je pak sve ok, na drugi zub ide do kraja kao sto i treba. (postoji mogucnost i da je obrnuta situacija, nisam 100% siguran, tek poenta je da je nesto reprogramirano :mad: ). Sta ciniti?
Poruka: 15311
Re: el. podizac stakala
Poruka od mbole » sreda, 31. avg. 2011. u 10:46h
Procitas uputstvo :)
Gde pise:
After the battery has been disconnected it is necessary to initialize each door window motor separately.
1. Press the power window control switch close button until the door window is fully closed and hold the button in the close position for a further second.
2. Release the power window control switch close button and press again two or three more times, for one second each time.
3. Press the power window control switch open button until the door window is fully open.
4. Briefly press the power window control switch close button to the second detent and release the button.
If the door window does not close automatically, repeat the complete procedure.
5. Repeat the door window motor initialization for each door window motor.
WARNING:
The door window anti-trap function will not operate during the door window motor initialization procedure. Make sure that the door window opening is free of all foreign material. Failure to follow this instruction may result in personal injury.
Poruka od BojanM » sreda, 31. avg. 2011. u 10:54h
Takođe, u gornjem desnom uglu foruma ima jedna zgodna opcija zvana "Pretraga" u koju ukucaš, na primer, "programiranje prozora mondeo" i dobiješ, na primer, ovu temu kao rezultat. thumbsuph
Što se radija tiče mogu da se nađu po netu programčići za dekodiranje, ali će biti neophodno da saznaš koji je serijski broj radio uređaja, a to je zapisano na samom njegovom kućištu... što će reći, neophodno ga je izvaditi iz maske instrument-table i ždraknuti šta piše na nalepnici.
@mbole, sve mi nešto miriše da kolega nije dobio original servisne knjižice i uputstva uz svoj automobil, čim nema ni šifru za radio.
Poruka: 15311
Poruka od mbole » sreda, 31. avg. 2011. u 11:26h
Ma pretpostavljam za knjizice (da ne kazem, znam da je to uobicajena pojava), al malo "drvim" :)
crow
Poruka: 103
Poruka od crow » sreda, 31. avg. 2011. u 11:58h
Jbg, 'talijanski jos ne naucih...ali cu morati po svemu sudeci ;)
BojanM piše:Takođe, u gornjem desnom uglu foruma ima jedna zgodna opcija zvana "Pretraga" u koju ukucaš, na primer, "programiranje prozora mondeo" i dobiješ, na primer, ovu temu kao rezultat. thumbsuph
Visio sam na ovoj temi X puta i pala mi je na pamet ali me secanje izdalo, bio sam ubedjen da nista o prozorima nisam procitao...
Hvala obojici na odgovorima u svakom slucaju.
Poruka: 15311
Poruka od mbole » sreda, 31. avg. 2011. u 12:44h
Proveri za svaki slucaj, da negde u toj knjizici nije zavrsio i kod od radija.
Obicno to ljudi cusnu unutra i zaborave za sva vremena.
Naravno uvek mozes da odes kod Ford dilera i da ti daju kod (sto ce naravno da naplate, koliko nemam pojma).
Povratak na „Instalacije“
