Zatezivanje bregaste i glave focus 1.6 16v
nenad995
Poruka: 34
Član foruma od: četvrtak, 27. avg. 2015. u 18:28h
Poruka od nenad995 » utorak, 3. sep. 2019. u 14:06h
Drugari treba mi pomoć. Zanima me na koliko "kila" se stežu šrafovi (ležajeva) bregaste i na koliko se steže glava motora?
U pitanju je ford focus 1.6 16v zetec se 2003-e godište
Poslato sa WAS-LX1 pomoću Tapatoka
Nenad :ford:
Poruka: 15281
Re: Zatezivanje bregaste i glave focus 1.6 16v
Poruka od mbole » utorak, 3. sep. 2019. u 14:22h
Bregasta
µ 3. CAUTION:
Lay the camshaft in place so that none of the cams is at full lift.
Note:
The camshaft bearing cap numbering starts at the timing belt end with E1 on the exhaust side and with I1 on the inlet side.
Note:
The exhaust camshaft has an additional cam for the camshaft position (CMP) sensor.
Install the camshafts and camshaft bearing caps.
l Lubricate the camshafts and camshaft bearings with engine oil before installation.
µ 4. Note:
Tightening sequence.
Fit the camshaft bearing cap and tighten the bolts in three stages.
l 1st Stage: One half turn on each bolt until the camshaft bearing cap meets the cylinder head.
l 2nd stage: 7 Nm
l 3rd stage: 45 degrees
redosled:
Glava
µ 1. Note:
Note:
The cylinder head is placed into two guide sleeves.
Note:
The cylinder head bolts can be re-used.
Attach the cylinder head.
l Make sure all mating faces are clean.
l Fit a new cylinder head gasket.
l Install the cylinder head, tightening in four stages in the sequence indicated.
l Stage 1: 15 Nm.
l Stage 2: 30 Nm.
l Stage 3 using Special Tool 303-174: 90 degrees.
redosled
