Mondeo MK5 2.0 TDCI - Mezimac
Enio
Poruka: 902
Lokacija: Temerin
Poruka od Enio » utorak, 30. jan. 2018. u 14:46h
Kao sto svi znate, Mezimica me je napustila, valjda se nisam dovoljno brinuo o njoj... :'( :'( :'(
Ali umjesto nje, dosao je novi Mezimac u kucu.
Da li je ovo slucajnost, ili sudbina, datum proizvodnje se poklapa sa mojim rodendanom :clap:
Mondeo MK5 Titanium, 2.0 sa 150 KS (ne zadugo), i automatskim mjenjacem.
Evo sto ETIS kaze o ovom autu:
Build Date: 26.09.2015
Vehicle Line: Mondeo 2014 -
Body Style: 5 Door Saloon
Version: Series 20
Engine: 2.0L Duratorq (150PS)
Transmission: 6 Speed Powershift 6DCT450 - MPS6
Drive: LHD FWD
Emission: Euro 6 Emissions
Air Conditioning: Dual Zone Auto Temp Control A/C
Territory: (+)"F"
Paint: Shadow Black (Mica)
Interior Fabric: Luxury Leather 2 / Charcoal Black
• Front Scuff Plates - Bright
• Auto Hi-Beam Headlamps
• My Key
• Luggage Compartment mat
• With Power Liftgate
• (-) SVP
• Exterior Paint - Solid
• With Electronic Stability Control
• With Breakdown Warning Sign
• Power Front Windows One Touch Up/Do
• Power Rear Window One Shot Up/Down
• With Privacy Glass
• Standard Green Glass Windscreen
• With Heated Windscreen
• With Locking Glove Box Lid
• Mini Overhead Cnsl W/Sunglass Bin
• Centre Console-Level 2
• Cup Holders (2) - Row 1
• Interior Trim - PVC/Leatherett
• Int Environment Clr-Charcoal Black
• Int Feat Colour - Charcoal Black
• With Level 2 Door Trim Panel
• 4 Load Compartment Tie Down Loops
• With Sound Insulation Pack Level 1
• Lower Grille - Hgh Gls W/Chrm Smile
• Active Grilleshutter
• Rocker Panel Moulding - Body Colour
• With Titanium Door Frame Mouldings
• With Electrochromic R/View Mirror
• Dual Pwr/Htd/Sig/Pdl Lmp/Fld/Dor
• With Body Coloured Exterior Mirror
• With Front Seat Back Stowage Pocket
• With Ski Bag Provision
• With Front 4 Way Headrest
• With Electric Driver Seat Recliner
• With Electric Pass.Seat Recliner
• Rr Centre Armrest Cover Stw/Cuphold
• Lumbar Seat - 2 Way Driver
• With Passenger Power Lumbar Support
• Driver Heated Seat-Variable Temp
• With Heated Pass Seat-Variable Temp
• 2nd Row Seat 60/40 (3 P) - Folding
• Drv Power Seat Adjust With Memory
• With Pass 10 Way Power Seat Adjust
• With Front Towing Hook
• With Rear Towing Hooks
• Heater Controls Alt A
• Engine Cover - Under Hood
• Body Coloured Exterior Door Handle
• With Leather Gear Shift Knob
• With Remote Controlled Tailgate Release
• Automatic Gearshift
• Power Door Lock With Elec Release
• Keyless Entry/Start - Passive
• Capless Fuel Filler With Lock
• With Int. Rear Window Wiper/Washer
• With Automatic Windscreen Wiper
• With Heated Washer Jet
• Air Curtain Restraint LH
• Air Curtain Restraint RH
• Inflatable Knee Bolsters - Driver
• With 3 Point Seat Belts
• With Standard Rear Seat Belts
• With Smart Drivers Airbag Restraint
• With Side Air Bag - Drivers Side
• With Side Air Bag - Passenger Side
• With Passenger Air Bag Deactivation
• With Isofix Hard Point Attachment
• With 16" Mini Steel Spare Wheel
• Tyre Pressure Sensors - 433 MHZ
• With Standard Rear Shock Absorbers
• 18 X 8.0" Alum Painted Euro Flange
• Spare Tyre-T125/80R16
• With Standard Tyre Tread - Front
• With Standard Tyre Tread - Rear
• Any Brand Tyre Vendor
• Cold Start -25 Deg C
• Starter - Stop/Start System
• Euro 6 Emissions
• With Standard Suspension
• Front Spring Load Class-U
• Rear Spring Load Class-I
• Sng Transverse Muffler/Dual Exhaust
• With Electric Parking Brake
• Low Speed Safety System
• With Brake Emergency Assist
• 4 Wheel Anti-Lock Braking System
• Select Shift Tech (SST) W/Pad Shift
• Sports Front Seat
• With Air Purifier Sensor
• Pollen/Carbon Filter
• With Recirculating Heater
• A/C Refrigerant-R134A
• With Clean Fuel Fleet Vehicle
• With Diesel Fuel Capability
• With Electric Power Steering
• With Manual Tilt/Slide Stg Column
• Leather Steering Wheel
• Speed Control And ASLD
• With Supplemental Air Heater
• Conv Instrmnt Hybrid - With TFT Dsp
• With KMH/MPH Speedometer
• With Trip Computer
• 7000 RPM Tachometer
• MFD TFT Touch Screen
• With Navigation System
• Lane Keeping Aid
• Speed Sign Recognition
• Human Machine Interface 4
• With Engine Immobilizer - Integral
• With Rear Parking Aid
• With Front Parking Aid
• ICE-Scd Dual/5th Ch/Tmc/Dab/Pd
• ICE Feature Pack 49
• With 8 Speakers
• Sync II
• Rear View Camera-Fixed
• With Chrome Fog Lamp Bezel
• With Halogen Headlamp
• With Daytime Running Lamps
• With Front Fog Lamps No.2
• With Interior Light Group
• Header Mounted Courtesy/Maplights
• With Courtesy Light Delay
• With Interior Courtesy Lamp
• With 2nd Row Reading Lamps
• With Glove Box Illumination
• Load Compartment Light - LED
• Tail lamps - Level 3
• With High Mounted Stop Lamp
• With Front Headlamp Levelling
• With Automatic Headlamp On/Off
Prvih 100 km sto sam napravio u njemu, MILINA.
Iako sam skoro napravio review S-Max-a, mogu reci da je udobnost u ovom autu identicna.
Mjenjac ne osjecam. Ovo mi je prvi automatik u zivotu, iako sam par njih vozio, ali na kratko. Mijenjanje brzina je ugladeno, nema skakanja, i kad se koriste rucice za brzine, takoder nema trzanja kod mijenjanja. Npr, prijatelj mi je kupio Peugeot 508, i tamo se debelo osjeti svaka brzina, a kad koristis rucice, skoro te trzaj odmakne od sica.
Auto je GROM. Gas reagira skoro ODMAH, i ako ga stisnes do daske, auto prepozna da ti trebaju visi obrtaji.
Jedino sto mi je zao da ovaj auto nema, su LED svjetla. Medutim, za nista nije kasno.... Vidjeti cemo i za to.
Unutarnja oprema... Sve sto je potrebno. Prepoznavanjeznakova, drzanje i pomoc u traci, automatska duga svjetla....ima vremena pisati o svemu.
Veceras obecajem malo vise slika kad su sve lampice popaljene mrgreen
A sad uzivajte u par brzih slika:
Za vrijeme kupovine:
Napokon kuci:
Idemo dalje :ford:
Poslednja izmena: Enio, na dan utorak, 30. jan. 2018. u 14:46h. Ukupno izmenjeno 1 put.
Novi Mezimac 2.0 A8 "V"
Poruka: 10006
Re: Mondeo MK5 2.0 TDCI - Mezimac
Poruka od macaneli » utorak, 30. jan. 2018. u 14:55h
Svaka cast gazda
uros.milenkovic6
Poruka: 219
Član foruma od: sreda, 20. dec. 2017. u 12:31h
Poruka od uros.milenkovic6 » utorak, 30. jan. 2018. u 15:00h
Srecnooooo sa mezimcem
Audi A6 Matrix Quattro S-line 2018. 2.0 TDI 190Hp
Ford Mondeo MK4 Titanium 2010. 2.0 Tdci oko 200Hp
Aca06
Poruka: 3227
Lokacija: Surčin
Poruka od Aca06 » utorak, 30. jan. 2018. u 15:10h
Srecno sa novim mezimcem. :bravo:
Sto se tice menjaca vrlo brzo ces se navici na njega i veruj mi da vise neces hteti da sednes u auto sa manuelnim menjacem.
Ovo ti kazem iz licnog iskustva,.
Almighty.shO
Poruka: 1786
Poruka od Almighty.shO » utorak, 30. jan. 2018. u 15:11h
Masala, extra je! Nek te sto duze sluzi! Bas je dobar (jedino su mi felne onako... ali verujem da ces naci vec neke vrhunske).
Voleo bih da mi je sledeci auto automatik, od toga nema bolje.
acadimke
Poruka: 1731
Lokacija: Novi Sad - Futog
Poruka od acadimke » utorak, 30. jan. 2018. u 15:13h
Srecno, gde su slike?
Poruka: 6106
Poruka od Daniel » utorak, 30. jan. 2018. u 15:15h
cestitke, nek te dugo sluzi ;)
Enio
Poruka: 902
Lokacija: Temerin
Poruka od Enio » utorak, 30. jan. 2018. u 15:17h
Hvala vam
acadimke piše:
Pa tu su. Sto se ne vide?
uros.milenkovic6
Poruka: 219
Poruka od uros.milenkovic6 » utorak, 30. jan. 2018. u 15:18h
Ne vide se
vucki
Poruka: 2146
Lokacija: beograd-jajinci
Poruka od vucki » utorak, 30. jan. 2018. u 15:19h
Prelep...ovog ces malo vise da briskas,za#ebana boja za odrzavanje 😁
acadimke
Poruka: 1731
Poruka od acadimke » utorak, 30. jan. 2018. u 15:19h
Ne vidim preko tapatalk-a, nema veze videcu na komp :)
Poruka: 13671
Poruka od dule0911 » utorak, 30. jan. 2018. u 15:47h
Neka te dugo i dobro sluzi :) Zameni ulje u menjacu sto pre da sprecis glavobolje.
Poruka: 6712
Poruka od vidovac » utorak, 30. jan. 2018. u 16:07h
Sa srecom da te sluzi ko i prethodni :)
Poruka: 2607
Poruka od Daki_81 » utorak, 30. jan. 2018. u 16:12h
Srećno i dugo da te vozi
Poruka: 4761
Poruka od Nedeljkovic » utorak, 30. jan. 2018. u 16:13h
Srecno Enio
Poruka: 5925
Poruka od FiestaBG87 » utorak, 30. jan. 2018. u 16:17h
Au :-D
Srećno :-)
Enio
Poruka: 902
Lokacija: Temerin
Poruka od Enio » utorak, 30. jan. 2018. u 16:22h
Hvala svima
Ovo mi se jako svida :woohoo: :woohoo: :woohoo:
Almighty.shO
Poruka: 1786
Poruka od Almighty.shO » utorak, 30. jan. 2018. u 16:32h
Koliko $$$? :) (ako nije tajna)
BokiRS
Neizleciv
Neizleciv
Poruka: 4458
Poruka od BokiRS » utorak, 30. jan. 2018. u 17:06h
Cestitam, super je 👍🏻
Chip tuning za Ford-ove
viewtopic.php?f=94&t=19067
Mirza_Capri_MK1
Poruka: 504
Član foruma od: ponedeljak, 16. dec. 2013. u 22:45h
Lokacija: Sarajevo
Poruka od Mirza_Capri_MK1 » utorak, 30. jan. 2018. u 17:09h
Brutalan je! Svaka cast. Reci i molim te, kako si izlistao sve to iz Etis-a? Ja kada ukucam broj sasije samo mi izbaci marku, mode, motor i boju.
Enio
Poruka: 902
Lokacija: Temerin
Poruka od Enio » utorak, 30. jan. 2018. u 17:23h
Logirao sam se i imam sve.
Almighty.shO piše:
Nije tajna, zasto bi bila, platio sam ga 17
Poruka od milan_gt » utorak, 30. jan. 2018. u 17:43h
Strava svaka cast, namesti na dijagnostici da se preko kljuca i zatvara..
Almighty.shO
Poruka: 1786
Poruka od Almighty.shO » utorak, 30. jan. 2018. u 18:01h
Enio piše:
Huh, za mene "previsoko" ali verujem da vredi svaki cent. Nema sumnje da si ti to dobro pregledao i da si obratio paznju na menjac...
Zavidim ti :D (ali u pozitivnom smislu, naravno).
Enio
Poruka: 902
Lokacija: Temerin
Poruka od Enio » utorak, 30. jan. 2018. u 18:14h
milan_gt piše:Strava svaka cast, namesti na dijagnostici da se preko kljuca i zatvara..
Upravo probao, zatvara se pomoću ključa. Nisam ni znao za to
Sent from my SM-G955F using Tapatalk
Poruka: 8386
Poruka od FM III » utorak, 30. jan. 2018. u 19:11h
Odličan. Neka je sa srećom i da te dugo i dobro služi mezimac kao što je i mezimica.
Vidi sa Romanom za LED svetla on ih je isto naknadno ugradio.
ps. možda je isti datum proizvodnje, ali je dostaaa mladji od tebe :D
