POGRESNO !!!!
Umalo ne polomih stop lampu jer slusam priucene ljude.Posto na youtubu nema,a nema nesto ni na netu, nasao sam na jednom jedinom mestu pa rekoh da podelim sa vama sigurno ce nekom trebati.
How to change a mk6 Fiesta rear brake bulb
I noticed that my partners brake light had stopped working the other day. Being the generous and thoughtful person I am I said "Don't worry babe, I'll change it for you". So off I popped to Halfords to buy a bulb set. Halfords 380 in case you need to know. "Would you like help fitting that sir?" asked the girl at the checkout. "No thanks" I replied. How hard can it be to fit a rear bulb to a Mk6 Fiesta? Fitting FROM £3.99 it said...
I got home and investigated the car. I noticed 2 star bolts. I thought undo them, take off cover and change bulb. Simple.
Oh no... this was NO five minute job for someone who does not know how to change the bulb. There was no way I was giving up. I decided to consult google as there was bound to be a tutorial or something to help right? Wrong. All I could find were forums of contradicting posts all asking my exact question, I have removed the 2 star bolts but what now? The light assembly simply will not budge. A few said yank it, a few said remove another bolt. But what other bolt? I can't see anything.
After an hour of trying to work it out and worrying if I would break something I did eventually manage to change the bulb on the left. It took less than 5 minutes for the right side. Easy when you know how! I decided to put this on my blog (with pictures) in the hope that someone else will find this exact how to and not the unhelpful discussions I found.
Changing a Ford Fiesta rear brake bulb. Here's what I did:
Step 2. Remove this WINGNUT - Yes there is a wingnut and this photo is proof. You need to fiddle a little but its there. It took 50 complete turns too so don't give up! It's up behind the light, there is a small hole you can put your hand in. Easier for smaller hands!
Step 3. Pull the light assembly, it may need a little force as there is a push fitting. Be careful because there is a connector on the back. Remove the connector by pressing the little 'tooth' down and pulling. It may need a little 'jiggle'.
Step 4. Unclip the Circuit strip board and remove the whole thing. At this point you could choose to replace all the bulbs in one go.
Step 5. Place everything back together carefully and fit back to the car. 5-10 minutes. Easy when you know how!
