Ford Focus 1.8 TDCI 85kw 2002 g. - problem sa paljenjem
Poruka: 8402
Re: Ford Focus 1.8 TDCI 85kw 2002 g. - problem sa paljenjem
Poruka od FM III » petak, 7. dec. 2018. u 12:50h
ljuba power
Poruka: 2752
Poruka od ljuba power » petak, 7. dec. 2018. u 17:43h
pre će biti k4 ili k219 jer dizel nema k13,k13 kontrolni relej kod benzinca
Poruka: 15281
Poruka od mbole » petak, 7. dec. 2018. u 18:29h
FordinaBiH piše:
petak, 7. dec. 2018. u 12:37h
Focus 1.8 tdci 85 kw 2002 (mada njegova dijagnostika kaze da je 2001 godina ali je facelift model)
Facelift je od avgusta 2001 (iako ga krste kao 2002)
Pogledaj jedanaesti i dvanaesti karakter broja sasije.
11 - godina (1-2001, 2-2002)
12 - mesec
Kôd: Označi sav tekst
                                          VIN Position 12 Ä Month of Manufacture
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄ¿
³          Month           ³   1998   ³   1999   ³   2000   ³   2001   ³   2002   ³   2003   ³   2004   ³   2005   ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄ´
³ January                  ³    L     ³    C     ³    B     ³    J     ³    L     ³    C     ³    B     ³    J     ³
³ February                 ³    Y     ³    K     ³    R     ³    U     ³    Y     ³    K     ³    R     ³    U     ³
³ March                    ³    S     ³    D     ³    A     ³    M     ³    S     ³    D     ³    A     ³    M     ³
³ April                    ³    T     ³    E     ³    G     ³    P     ³    T     ³    E     ³    G     ³    P     ³
³ May                      ³    J     ³    L     ³    C     ³    B     ³    J     ³    L     ³    C     ³    B     ³
³ June                     ³    U     ³    Y     ³    K     ³    R     ³    U     ³    Y     ³    K     ³    R     ³
³ July                     ³    M     ³    S     ³    D     ³    A     ³    M     ³    S     ³    D     ³    A     ³
³ August                   ³    P     ³    T     ³    E     ³    G     ³    P     ³    T     ³    E     ³    G     ³
³ September                ³    B     ³    J     ³    L     ³    C     ³    B     ³    J     ³    L     ³    C     ³
³ October                  ³    R     ³    U     ³    Y     ³    K     ³    R     ³    U     ³    Y     ³    K     ³
³ November                 ³    A     ³    M     ³    S     ³    D     ³    A     ³    M     ³    S     ³    D     ³
³ December                 ³    G     ³    P     ³    T     ³    E     ³    G     ³    P     ³    T     ³    E     ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÙ
ljuba power
Poruka: 2752
Poruka od ljuba power » petak, 7. dec. 2018. u 20:08h
ako imaš napajanje na grejačima kod hladnog motora engine control relej ispravno radi.tako ćeš ga naj lakše ispitati
FordinaBiH
Poruka: 17
Član foruma od: subota, 31. mar. 2018. u 23:13h
Poruka od FordinaBiH » subota, 8. dec. 2018. u 11:16h
A sta je sa kodiranje dizni. Nikako ne moze da ubaci nove kodove.
Dobio sam 4 papira na kojima pisu kodovi dizni sa rednim brojem dizne i te kodove ne moze da ubaci "predpostavljam" u kompjuter auta ili kompjuter dizni (ako se ne varam)
Na ovoj dijagnostici (fordova 2018) kako ubacuje kodove sve se cini normalno i onaj zeleni strihir prihvati poslije svake unesene kombinacije brojeva i slova za jednu diznu. Ali kada ponovo otvori da provjeri kodove na istom mjestu stoje sve nule.
Da lu su kodovi prihvaćeni.
Poruka: 6712
Poruka od vidovac » subota, 8. dec. 2018. u 11:39h
Mozda ti je crkao komp za dizne i zato ne moze da ubaci nove kodove. I restajl.modeli su u pocetku imali odvojen komp za dizne
ljuba power
Poruka: 2752
Poruka od ljuba power » subota, 8. dec. 2018. u 12:37h
svi tdci imaju odvojen inj.control modul do 07,2002g...jel pali taj auto uopšte
FordinaBiH
Poruka: 17
Poruka od FordinaBiH » subota, 8. dec. 2018. u 14:48h
Auto pali i vozi. Mijenjan je taj tzv "kompjuter dizni" al opet nemoze da ucita nove kodove
ljuba power
Poruka: 2752
Poruka od ljuba power » subota, 8. dec. 2018. u 20:11h
loša dijagnostika...jel to vcm2 v110 verzija?
FordinaBiH
Poruka: 17
Poruka od FordinaBiH » sreda, 26. dec. 2018. u 13:11h
Da li se prilikom demontaze i monzaze pumpe visokog pritiska mora skidati zupcati tj. da li je ona spojena na zupcasti remen
Poruka: 6712
Poruka od vidovac » sreda, 26. dec. 2018. u 13:35h
Mora da se skine i zupcasti, i lanac koji ide od radilice do pumpe
FordinaBiH
Poruka: 17
Poruka od FordinaBiH » sreda, 26. dec. 2018. u 13:41h
Hvala drug jer mi je upravo pukao zupcasti remen nakon remonta kompletnog sistema ubrizgavanja (zamjenjena pumpa visokog pritiska, reparirane dizne, skinut rezervar + sva crijeva tj. sve ocisceno) nakon 7 dana. A zupcasti je mijenjan prije 20.000 km. opet do majstora
Bože dragi
Koja je sad nastala steta na autu tj. motoru.
Nakon pomenutog remonta primjetio sam ulje ispod auta (sljedeće jutro nakon preuzeća od majstora) i kao bio problem na semeringu pumpe visokog pritiska. 5-6 dana nakon toga desi se ovo
Poruka: 6712
Poruka od vidovac » sreda, 26. dec. 2018. u 13:44h
Umastio se zupcasti i pojelo ga uljem. Steta na motoru je sigurnobda su klipovi stigli ventile i da ces morati da radis glavu, znaci komplet ventili gumice obrada i sve to ide uz to, plus majstor da sve to namesti, plus veliki servis. Kad se skida pumpa.obavezno se menja taj semering koji ide na pumpu jer se osteti prilikom skidanja, a on je tipa nesto 500-1000 dinara
serbianum
Poruka: 38
Član foruma od: subota, 23. jun 2018. u 16:26h
Poruka od serbianum » sreda, 26. dec. 2018. u 15:31h
Nemoj da zaboraviš da kupiš kurblu kada sve to završiš. Nažalost
montoya
Poruka: 2195
Lokacija: Jagodina
Poruka od montoya » sreda, 26. dec. 2018. u 16:09h
Nije bas 500 din ali nije preko 2500 sigurno, i obavezno ide novi zupcasti kada se umaze uljem...
Ford mondeo mk4.5 2023-
Ford Ka mk2 2021-2025
Volvo v50 1.6 d2 2019-2023
Ford KA 1.3 2019-2021
Maverick 2.0 Zetec 2018-2022
C Max 06. 1.8 tdci 2016-2019
FordinaBiH
Poruka: 17
Poruka od FordinaBiH » sreda, 26. dec. 2018. u 17:32h
Klasican primjer sposobnosti nasih majstora
galac68
Poruka: 7
Član foruma od: ponedeljak, 2. feb. 2015. u 20:15h
Lokacija: Užice
Poruka od galac68 » nedelja, 16. avg. 2020. u 22:41h
"kodiranje dizni" ovo je izmislila Struka od majstora. Nit oni znaju niti umeju.
Dizne se kalibriraju tjst premere im se parametri a zatim se ti parametri unose u racunar auta. Na osnovu tih parametara komjuter steluje protok i ubrizgavanje dizni.
:ford: fokus je ko fikus- traži redovno zalivanje i održavanje lišća.
Poruka: 15281
Poruka od mbole » nedelja, 16. avg. 2020. u 23:44h
Kao i gomila drugih stvari, to je jednostavno zargon.
Tehnicki naravno nije ispravan, vuce na pogresan zakljucak sta se ustvari radi, ali kada jednom svi znamo na sta se misli... sta je problem?
Kao sto imas "kodiranje kljuca", koje uopste nista ne radi na kljucu, vec kaze GEM-u koji kljuc da prihvati... al znamo da je to to... i no problem.
Meni smeta kada neko ko bi trebalo da je tehnicki obrazovan, to jest majstor koristi pogresne termine. Uopste ne ocekujem od diplomiranog ekonomiste, bibliotekara, trgovca ili istoricara da ima pojma o cemu se radi, a jos manje da koristi tehnicki ispravan termin.
