Mondeo mk 3 2.5 V6
Re: Mondeo mk 3 2.5 V6
Poruka od BojanM » četvrtak, 5. jan. 2017. u 14:06h
duratecHE piše:Ima liima li taj agr veze sa onim u jaguaru x
Srodne duše.
https://en.wikipedia.org/wiki/Jaguar_AJ-V6_engine
Poruka: 5143
Poruka od Sharpshooter » četvrtak, 5. jan. 2017. u 16:01h
dule0911 piše:Ako se dobro secam ovaj je imao famoznih 44 kubika viska u ranijim godistima, u mk3 su ispravili propust.
2.5 L
The Duratec 25 is a 2.5 L (2544 cc) 60° V6 and was introduced in 1994. It was developed for the Ford Contour and also used in the Ford Mondeo and others. Bore is 82.4 mm (3.2 in) and stroke is 79.5 mm (3.1 in).
The Duratec 25 was on the Ward's 10 Best Engines list for 1995 and 1996, and the SVT version made the list for 1998 and 1999.
Duratec VE
The 2.5 L, 170 hp (130 kW) V6 used in the third generation Ford Mondeo is called the Duratec VE. Displacement was decreased from 2544 to 2495 cc. They were also used in the Ford Cougar.
Bravo Dule. ;)
Poruka: 13655
Poruka od dule0911 » četvrtak, 5. jan. 2017. u 16:14h
Sta me hvalis, samo sam zapamtio brojku od ranije :D Inace je motor razvijen u saradnji sa Yamahom i sluzio je kao osnova za Aston Martin 6.0 V12 motor (3.0 verzija, ali sustinski isti motor).
Kako god, smatram da je ovo najbolja motorizacija u mk3 mondeu, kome se svidja benzinac. Mada, nece zaostajati mnogo ni za dizelom u niskim obrtajima, samo ce imati mnogo glatkiju isporuku snage pa ce zavarati da je sporiji.
Aleksandar86
Poruka: 465
Poruka od Aleksandar86 » četvrtak, 5. jan. 2017. u 16:41h
Dobar mondiša, a još bolje što je benzin thumbsuph neka dobro služi :beer:
Ford Focus 1.8 16V 2004.
zekavr
Poruka: 440
Lokacija: vranje
Poruka od zekavr » četvrtak, 5. jan. 2017. u 21:16h
sjajan auto,da zivimo u normalnijoj drzavi bilo bi ih vise,a ne da se prvo pitamo kako cu platiti registraciju :doh: !
u zdravlju da ga vozis thumbsuph
Djotta
Poruka: 22
Član foruma od: nedelja, 11. dec. 2016. u 01:35h
Lokacija: Cacak
Poruka od Djotta » petak, 20. jan. 2017. u 22:21h
Ostao sam dužan par slika motora :)
Moraću da ga očistim kad prođe zima :ford:
Poruka od BojanM » subota, 21. jan. 2017. u 00:09h
Ne znam zašto, ali volim da vidim ovaj motor u kolima, pa to ti je. thumbsuph
A ne smeta mi ni kad se vidi da se auto vozi, bolje da je ispod haube prašina nego uljano kupatilo. ;)
