Stezanje Glave Escort MK4 (Hitno)
Nije mesto za kvarove.
adnan89
Poruka: 349
Član foruma od: utorak, 2. feb. 2010. u 01:01h
Poruka od adnan89 » sreda, 9. feb. 2011. u 10:26h
Interesuje me redoslijed stezanja sarafa i koliko kg po sarafu...
Da li ide ono tri puta, 8-10-12 kg ili kako vec???
Hitno mi je : mechanic
Dusan64
Poruka: 5283
Re: Stezanje Glave Escort MK4 (Hitno)
Poruka od Dusan64 » sreda, 9. feb. 2011. u 10:35h
Torque wrench settings Nm lbf ft
Main bearing caps . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 to 100 66 to 74
Connecting rod bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 to 36 22 to 26
Oil pump to crankcase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 to 11 6 to 8
Oil pump cover bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 to 11 6 to 8
Oil pump pick-up tube to block . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 to 23 12 to 17
Oil pump pick-up tube to pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 to 11 6 to 8
Oil cooler threaded sleeve to block . . . . . . . . . . . . . . . . . . . . . . . . . . . . 55 to 60 40 to 44
Rear oil seal carrier bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 to 11 6 to 8
Sump with multi-piece gasket:
Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 to 11 6 to 8
Stage 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 to 11 6 to 8
Sump with one-piece gasket:
Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 to 8 4 to 6
Stage 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 to 8 4 to 6
Flywheel to crankshaft . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82 to 92 60 to 68
Torque converter drive plate to crankshaft . . . . . . . . . . . . . . . . . . . . . . . 80 to 88 59 to 65
Crankshaft pulley bolt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 to 115 74 to 85
Cylinder head bolts:
Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 18
Stage 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 55 40
Stage 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Tighten by a further 90° Tighten by a further 90°
Stage 4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Tighten by a further 90° Tighten by a further 90°
Dusan64
Poruka: 5283
Poruka od Dusan64 » sreda, 9. feb. 2011. u 10:40h
Nije se bas lepo kopiralo.. Uglavnom koliko se secam otrpilike,stezes prvi put odmah na 5kg,onda posle za 90stepeni i jos jednom za 90stepeni. Ali ne odmah,nego posle neke predjene kilometraze..
Ovo te zanima:
Zavisi u kojim merema ti je kilo kljuc,prvo su ti Nm,drugo Lbf ft. Mada ja bih odmah isao na 5kg.
Inace ako si kupio nov dihtung na njemu mora da pise sta je najbolje za njega.
adnan89
Poruka: 349
Poruka od adnan89 » sreda, 9. feb. 2011. u 10:50h
a sta ti znaci to 90° ?
kljuc ima i Nm i KG
Dusan64
Poruka: 5283
Poruka od Dusan64 » sreda, 9. feb. 2011. u 11:20h
Onda idi na 50-55Nm prvo stezanje. 90° znaci 90 stepeni.. lol Ali to ti je drugo stezanje,znaci stavis kljuc ravno u odnosu na nesto i stegnes za 90 stepeni i tako i treci put.
adnan89
Poruka: 349
Poruka od adnan89 » sreda, 9. feb. 2011. u 11:34h
ima sve na dihtungu pise vid budale
Dusan64
Poruka: 5283
Poruka od Dusan64 » sreda, 9. feb. 2011. u 11:46h
Pa kazem ja.. Mada ako pise da treba 5-6puta to ignorisi.. Idi onako kako sam ti rekao.. Sta si mu sad radio?
adnan89
Poruka: 349
Poruka od adnan89 » sreda, 9. feb. 2011. u 18:11h
ide prvo 2,5 kg, pa 5,5 kg, pa onda -90° + 5,5 kg, pa dva puta po 90°...
stego i radi...
uskoro cu ubacit slike
ma nisam mu nista radio, procurio na vanjsku stranu i kvasio mi motor.
Dusan64
Poruka: 5283
Poruka od Dusan64 » sreda, 9. feb. 2011. u 19:36h
Pa tako pise u manuelu,ali mogao si opusteno odmah na 5kg.. Ko ce 7puta da skida deklu,nema potrebe za tim...
adnan89
Poruka: 349
Poruka od adnan89 » sreda, 9. feb. 2011. u 23:23h
ma jok, ja sam to od prve tako stego, ne otvaram ja to vise. hahaha
Poruka: 9044
Poruka od van » sreda, 9. feb. 2011. u 23:40h
Mnogo je u startu 5,5 kg . JA bi isao na pola od te vrednosti , pa ponovo bi prosao sve sa 2.5 kg , pa onda 5.5 kg , pa jos jednom sve 5.5kg da dotegnes , pa onda to sa 90 stepni ...
A sto ne ispusti vodu pre skidanja glave nego davis klipove mrgreen
Inace , lepo sagorevane ,
adnan89
Poruka: 349
Poruka od adnan89 » sreda, 9. feb. 2011. u 23:53h
joj tebe VAN, ovo mi je prvi put
a vidi sta se desilo sa ventilima na usisu, ne mogu ostrugat koliko se nalijepilo. jel to zbog plina ili?
Dusan64
Poruka: 5283
Poruka od Dusan64 » četvrtak, 10. feb. 2011. u 00:15h
I ja sam imao isto takve naslage na ventilima.. Ali ih nisam ni dirao.. Trebao si da narucis druge klipove kod Sime.. Covek mi je poslao kao nov klip sa klipnjacom i novim karikama za 10e.. Da sam znao da je takav covek uzeo bih sva 4.. Ko ce da je steze 7puta,ionako previse vremena provodimo ispod haube.. :D
